[postgis-devel] What is the correct way to remove a sql-signature
Nicklas Avén
nicklas.aven at jordogskog.no
Mon Aug 26 04:23:30 PDT 2013
Hallo
TWKB has changed to VarInts instead of my homebrewed compression method.
Then the byte order is defined n the VarInt concept so I have removed the option to decide byteorder of input.
But when I remove the sql-signatures with endianess option from postgis.sql.in and rerun configure I get into problems with comment.sql missing those functions.
What is the right way to do this?
Is it just a question of triggering a new version of comment.sql or do I have to do some further changes?
Thanks
Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130826/071cb5e7/attachment.html>
