[postgis-devel] What is the correct way to remove a sql-signatur
Nicklas Avén
nicklas.aven at jordogskog.no
Mon Aug 26 11:47:11 PDT 2013
Thank you Regina
I was starting to suspect that there was a connection with the manual.
Actually quite good. It makes it more difficult to cheat with doc :-)
Thanks
Nicklas
On Mon, 2013-08-26 at 14:21 -0400, Paragon Corporation wrote:
> > But when I remove the sql-signatures with endianess option from
> postgis.sql.in and rerun configure I get into problems with comment.sql
> missing those
> > functions.
> > What is the right way to do this?
> > Is it just a question of triggering a new version of comment.sql or do I
> have to do some further changes?
> You have to correct the manual and then trigger a new build of comments.
> The manual won't allow you to document invalid signatures; kind of an
> accidental feature of having a code integrated manual :)
> Hope that helps,
> Regina
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
