[postgis-devel] OGC TIN of triangles or polygons?
Olivier Courtin
olivier.courtin at oslandia.com
Mon Dec 2 01:53:44 PST 2013
On Dec 2, 2013, at 12:44 AM, Brent Wood wrote:
> The same applies to a rectangle - 5 points stored instead of 4 - so where do we draw the line?
> How many vertices must a polygon have before we follow the spec & explicitly close it?
Well the point was not to want to change anything in the spec implementation (e.g WKT/WKB import/export)
but 'only' a thought on the PostGIS triangle internal representation,
in order to avoid redundant coordinates internal storage.
On Polygon it will be harder to do the same, because a Polygon could have several rings
(a triangle not), so if we wanted to do so (e.g flag is_closed on polygon),
we would loose information on which rings is/are not closed (if any).
> I agree that the closing vertex is redundant, & can be replaced by a bit in the header - but by doing so we lose the ability to test for is it REALLY closed, rather than just saying it is closed, perhaps less important for triangles, but a capability I'm reluctant to lose.
As the flag would be internal, the only information lost, for triangles, would be:
what are the final coordinates if unclosed (and so invalid).
But i agree it's already a lost.
O.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131202/2e7af2a9/attachment.html>
