[postgis-devel] ST_Intersection(line,line) error
Paul Ramsey
pramsey at cleverelephant.ca
Tue Dec 3 09:41:54 PST 2013
Another workaround is to slightly buffer one of the lines
http://postgis.net
http://cleverelephant.ca
On December 3, 2013 at 9:36:25 AM, Rémi Cura (remi.cura at gmail.com) wrote:
Correction :
it gives the right extremities, but so the segments between are lost.
A work around is to use ST_Split(line,point) instead,
while snapping point to line (closestPoint)
but this is painfull
Cheers,
Rémi-C
2013/12/3 Rémi Cura <remi.cura at gmail.com>
Hey list,
ST_Intersection(line,line) seems to be faulty in the above case:
It should return a line , but strangely enough it returns multipoints with the correct points of the line it should return.
I guess I should be happy to have an answer at all.
Any thought?
Cheers,
Rémi-C
SELECT row_number() over() as id, ST_AsText(ST_Intersection(l1,l2)), ST_Intersection(l1,l2) AS the_intersection, l1,l2
FROM ST_GeomFromtext(' LINESTRING(1602.31065385555 21488.8919364873,1601.3 21494.4,1598.5 21510.2)') AS l1,
ST_GeomFromText('LINESTRING(1605.3 21472.6,1601.3 21494.4,1601.21138045673 21494.9000674227)') AS l2
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131203/f8e426fc/attachment.html>
