[postgis-devel] bug with postgis backend
Oliver Courtin olivier.courtin at oslandia.com
Mon Dec 9 07:06:42 PST 2013
Le 3 déc. 2013 à 17:41, Rémi Cura a écrit :
Hi Rémi,
> an exotic and anecdotal bug:
> I deleted all tables in a schema (not postgis schema) using cascade.
> I used several connection with pgadmin.
> Then I couldnt use any ppostgis function with the error "trying to set postgis.backend"
> setting or resetting postgis.backend wouldn't do anything.
> I add to close all and restart everything.
> I think this may be related to having the postgis.backend set to sfcgal with some connection while having other to geos, and recompiling postgis without sfcgal
I don't really understand what you really did.
You mention deleting tables,
then recompiling postgis without sfcgal.
Could you on your own platform reproduce it ?
BTW:  Opening a ticket is the right way to handle thing like that.
O.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131209/1a4af15b/attachment.html>
