[postgis-devel] PostGIS 2.1 "transaction control statements"
Stephen Mather mather.stephen at gmail.com
Sat Feb 9 22:56:12 PST 2013
But if I copied those scripts from my install into their correct final
location, that would explain the strange affect, eh?
I think this is the result of some advanced work-arounds... .
Best,
Steve
On Sat, Feb 9, 2013 at 12:45 PM, Paragon Corporation <lr at pcorp.us> wrote:
> If you compiled --without-raster then extensions should not have built at
> all since they don't build without raster.
> So that I suppose could be the problem.  if that is the case.  Please
> ticket it.  The extension files shouldn't have even tried to build at all.
> thanks,
> Regina
> *From:* postgis-devel-bounces at lists.osgeo.org [mailto:
> postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Stephen Mather
> *Sent:* Friday, February 08, 2013 11:00 PM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] PostGIS 2.1 "transaction control
> statements"
>   select version() || ' ' || ' ' || postgis_full_version();
> yields
> PostgreSQL 9.1.7 on x86_64-unknown-linux-gnu, compiled by gcc
> (Ubuntu/Linaro 4.7.2-2ubuntu1) 4.7.2, 64-bit  POSTGIS="2.1.0SVN r11081"
> GEOS="3.4.0dev-CAPI-1.8.0 r3762" PROJ="Rel. 4.7.1, 23 September 2009"
> LIBXML="2.8.0" LIBJSON="UNKNOWN"
> Looking through my history, it was an SVN pull:
> svn checkout http://svn.osgeo.org/postgis/trunk/ postgis-2.1.0SVN
> cd postgis-2.1.0SVN/
> ./autogen.sh
> ./configure --with-gui --with-topology
> ./configure --with-gui --without-raster --with-topology
> make
> make comments
> make cheatsheets
> sudo make install
> sudo ldconfig
> sudo make comments-install
> :D  Looks like I was feeling my way around in the dark a bit there... .
> On Fri, Feb 8, 2013 at 10:20 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Which version of trunk are you running with and where did you get it
>> from: Direct from svn or tar ball (and if tar ball what link)?
>> I just tried with Winnie's 9.2 latest Windows build built fresh whenever
>> there is a change and it installed fine creating a new postgis. Didn't try
>> 9.1 though.
>> PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
>> POSTGIS="2.1.0SVN r11085" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0, 6
>> March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
>> LIBJSON="UNKNOWN" RASTER
>> If you are running an older -- its possible there was a temporary issue
>> that was fixed, though I'm not aware of one.
>> In the make sed strips out all BEGIN COMMITS as well as a bunch of other
>> things that are illegal in extension scripts and replaces them with
>> equivalent extension commands.  It also adds additional helper functions it
>> uses during the process and then drops after.
>> *Sent:* Friday, February 08, 2013 5:13 PM
>> statements"
>>   -- $Id: postgis.sql.in.c 10806 2012-12-06 17:56:37Z pramsey $
>> BEGIN;
>> Yes, the BEGIN and END are there.  So, how does it work?  In the MAKE of
>> the extension, sed is supposed to strip out all transaction statements, or
>> this just slipped into the SVN somehow?
>> Best,
>> Steve
>> On Fri, Feb 8, 2013 at 4:37 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> Hmm that's the same version I'm runnning though I'm running mine under
>>> mingw.
>>> I thought maybe you were having a sed issue that someone else complained
>>> about, though they were on Mac and had to do with sed compatibility switch.
>>> In your extension folder of your PostgreSQL install,
>>> If you open up postgis-2.1.0SVN.sql
>>> Does it start with BEGIN and end with a COMMIT;?
>>> If it does -- remove those.  The postgis extension build line:
>>> sql_bits/postgis.sql: ../../postgis/postgis.sql
>>>  sed -e 's/BEGIN;//g' -e 's/COMMIT;//g'  $< > $@
>>>  should have done this but it sounds like it didn't for some reason.
>>> Those commands aren't legal in an extension script since the extension
>>> machinery already wraps an extension in a transaction.
>>> Hope that helps,
>>> Regina
>>> *Sent:* Friday, February 08, 2013 4:24 PM
>>> statements"
>>>   GNU sed 4.2.1
>>> On Fri, Feb 8, 2013 at 3:08 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>>> It sounds like the BEGIN /END transaction did not get stripped in your
>>>> extension building.
>>>> What version of sed do you have?
>>>> Thanks,
>>>> Regina
>>>> http://www.postgis.us
>>>> http://postgis.net
>>>> *Sent:* Friday, February 08, 2013 9:19 AM
>>>> *To:* postgis-devel at lists.osgeo.org
>>>> *Subject:* [postgis-devel] PostGIS 2.1 "transaction control statements"
>>>>    Hi All,
>>>>        Bounce me to users, if appropriate, but I have put together an
>>>> SVN build of PostGIS on Ubuntu 12.10 and postgresql 9.1, with GEOS
>>>> 3.4.0dev.  All went well in the configure/make/make install mantra.  When I
>>>> got to the CREATE EXTENSION step I got the following cryptic message:
>>>> "transaction control statements are not allowed with an extension
>>>> script"
>>>> I've had no problem loading PostGIS using the old method with sql
>>>> scripts, but thought I'd highlight this oddity in case it was useful and as
>>>> yet unreported.
>>>> Best,
>>>> Steve Mather
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130210/12988307/attachment.html>
