[postgis-devel] PostGIS 2.1 "transaction control statements"
Stephen Mather
mather.stephen at gmail.com
Sun Feb 10 09:54:36 PST 2013
We'll call it misdirected agile sys admin work... .
On Sun, Feb 10, 2013 at 4:24 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Depends. The files should not have been created in extensions folder of
> your source tree which are the ones that are copied to extension folder of
> PostgreSQL install.
> But if you copied the generated postgis.sql from regular source folder
> then yes that would explain it becuase the extension system would see that
> as the file to use and then scream violently when it realized you tried to
> trick it with an imposter :)
> *From:* postgis-devel-bounces at lists.osgeo.org [mailto:
> postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Stephen Mather
> *Sent:* Sunday, February 10, 2013 1:56 AM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] PostGIS 2.1 "transaction control
> statements"
> But if I copied those scripts from my install into their correct final
> location, that would explain the strange affect, eh?
> I think this is the result of some advanced work-arounds... .
> Best,
> Steve
> On Sat, Feb 9, 2013 at 12:45 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> If you compiled --without-raster then extensions should not have built at
>> all since they don't build without raster.
>> So that I suppose could be the problem. if that is the case. Please
>> ticket it. The extension files shouldn't have even tried to build at all.
>> thanks,
>> Regina
>> *Sent:* Friday, February 08, 2013 11:00 PM
>> statements"
>> select version() || ' ' || ' ' || postgis_full_version();
>> yields
>> PostgreSQL 9.1.7 on x86_64-unknown-linux-gnu, compiled by gcc
>> (Ubuntu/Linaro 4.7.2-2ubuntu1) 4.7.2, 64-bit POSTGIS="2.1.0SVN r11081"
>> GEOS="3.4.0dev-CAPI-1.8.0 r3762" PROJ="Rel. 4.7.1, 23 September 2009"
>> LIBXML="2.8.0" LIBJSON="UNKNOWN"
>> Looking through my history, it was an SVN pull:
>> svn checkout http://svn.osgeo.org/postgis/trunk/ postgis-2.1.0SVN
>> cd postgis-2.1.0SVN/
>> ./autogen.sh
>> ./configure --with-gui --with-topology
>> ./configure --with-gui --without-raster --with-topology
>> make
>> make comments
>> make cheatsheets
>> sudo make install
>> sudo ldconfig
>> sudo make comments-install
>> :D Looks like I was feeling my way around in the dark a bit there... .
>> On Fri, Feb 8, 2013 at 10:20 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>> Which version of trunk are you running with and where did you get it
>>> from: Direct from svn or tar ball (and if tar ball what link)?
>>> I just tried with Winnie's 9.2 latest Windows build built fresh whenever
>>> there is a change and it installed fine creating a new postgis. Didn't try
>>> 9.1 though.
>>> PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
>>> POSTGIS="2.1.0SVN r11085" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0, 6
>>> March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
>>> LIBJSON="UNKNOWN" RASTER
>>> If you are running an older -- its possible there was a temporary issue
>>> that was fixed, though I'm not aware of one.
>>> In the make sed strips out all BEGIN COMMITS as well as a bunch of other
>>> things that are illegal in extension scripts and replaces them with
>>> equivalent extension commands. It also adds additional helper functions it
>>> uses during the process and then drops after.
>>> *Sent:* Friday, February 08, 2013 5:13 PM
>>> statements"
>>> -- $Id: postgis.sql.in.c 10806 2012-12-06 17:56:37Z pramsey $
>>> BEGIN;
>>> Yes, the BEGIN and END are there. So, how does it work? In the MAKE of
>>> the extension, sed is supposed to strip out all transaction statements, or
>>> this just slipped into the SVN somehow?
>>> Best,
>>> Steve
>>> On Fri, Feb 8, 2013 at 4:37 PM, Paragon Corporation <lr at pcorp.us> wrote:
>>>> Hmm that's the same version I'm runnning though I'm running mine under
>>>> mingw.
>>>> I thought maybe you were having a sed issue that someone else
>>>> complained about, though they were on Mac and had to do with sed
>>>> compatibility switch.
>>>> In your extension folder of your PostgreSQL install,
>>>> If you open up postgis-2.1.0SVN.sql
>>>> Does it start with BEGIN and end with a COMMIT;?
>>>> If it does -- remove those. The postgis extension build line:
>>>> sql_bits/postgis.sql: ../../postgis/postgis.sql
>>>> sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' $< > $@
>>>> should have done this but it sounds like it didn't for some reason.
>>>> Those commands aren't legal in an extension script since the extension
>>>> machinery already wraps an extension in a transaction.
>>>> Hope that helps,
>>>> Regina
>>>> *Sent:* Friday, February 08, 2013 4:24 PM
>>>> statements"
>>>> GNU sed 4.2.1
>>>> On Fri, Feb 8, 2013 at 3:08 PM, Paragon Corporation <lr at pcorp.us>wrote:
>>>>> It sounds like the BEGIN /END transaction did not get stripped in your
>>>>> extension building.
>>>>> What version of sed do you have?
>>>>> Thanks,
>>>>> Regina
>>>>> http://www.postgis.us
>>>>> http://postgis.net
>>>>> *Sent:* Friday, February 08, 2013 9:19 AM
>>>>> *To:* postgis-devel at lists.osgeo.org
>>>>> *Subject:* [postgis-devel] PostGIS 2.1 "transaction control
>>>>> statements"
>>>>> Hi All,
>>>>> Bounce me to users, if appropriate, but I have put together an
>>>>> SVN build of PostGIS on Ubuntu 12.10 and postgresql 9.1, with GEOS
>>>>> 3.4.0dev. All went well in the configure/make/make install mantra. When I
>>>>> got to the CREATE EXTENSION step I got the following cryptic message:
>>>>> "transaction control statements are not allowed with an extension
>>>>> script"
>>>>> I've had no problem loading PostGIS using the old method with sql
>>>>> scripts, but thought I'd highlight this oddity in case it was useful and as
>>>>> yet unreported.
>>>>> Best,
>>>>> Steve Mather
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130210/6dd46f75/attachment.html>
