[postgis-devel] [raster] Testing out-db and regular blocking
Mateusz Loskot
mateusz at loskot.net
Tue Feb 26 07:28:58 PST 2013
On 26 February 2013 14:47, Bborie Park <dustymugs at gmail.com> wrote:
> Which version of PostGIS are you running? The constraint should be
> the same regardless of where the data is store.
Hi Bborie,
Apology for rookie's error, I should have included the version.
As the Gist description says, I run build based on SVN trunk r11115.
I also use GEOS and GDAL from their SVN trunks.
> But, does the account running the postgres server have
> access to the out-db raster?
Yes, I think so:
postgres:~$ ps -ef|grep '9.1/bin/postgres'
postgres 1012 1 0 10:09 ? 00:00:00
/usr/lib/postgresql/9.1/bin/postgres -D /var/lib/postgresql/9.1/main
-c config_file=/etc/postgresql/9.1/main/postgresql.conf
postgres:~$ ls -l /home/mloskot/data/geotiff/world.tif
-rw-r--r-- 1 mloskot mloskot 411822 Apr 14 2008
postgres:~$ gdalinfo /home/mloskot/data/geotiff/world.tif
Driver: GTiff/GeoTIFF
Files: /home/mloskot/data/geotiff/world.tif
/home/mloskot/data/geotiff/world.tif.aux.xml
Size is 512, 256
So, user postgres has access to the the world.tif file owned by user mloskot.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
