[postgis-devel] [raster] Testing out-db and regular blocking
Mateusz Loskot mateusz at loskot.net
Tue Feb 26 07:39:34 PST 2013
On 26 February 2013 15:32, Bborie Park <dustymugs at gmail.com> wrote:
> Ah.  I see what might be going on.  It looks like there's an error
> creating the implicit exclusion index for the
> enforce_spatially_unique_rast constraint.  It looks like postgres
> tries to create the exclusion index with the same name as the
> constraint, but fails as it already exists...
> NOTICE:  ALTER TABLE / ADD EXCLUDE will create implicit index
> "enforce_spatially_unique_rast" for table "indb"
> NOTICE:  Returned error message: relation
> "enforce_spatially_unique_rast" already exists
> Confirmed using a simplified test case.  I wonder if this is the
> expected behavior in PostgreSQL.
> CREATE TABLE foo AS
>         SELECT
>                 id
>         FROM generate_series(1, 5) t(id);
> CREATE TABLE bar AS
>         SELECT
>                 id
> ALTER TABLE foo
>         ADD CONSTRAINT enforce_unique_id EXCLUDE (id WITH =);
> ALTER TABLE bar
Bborie,
Yes, it looks you've pinned down the problem:
$ raster2pgsql -R -C -r  /home/mloskot/data/geotiff/world.tif t1 > t1.sql
$ psql -d rasters2 -f t1.sql
psql:t1.sql:4: NOTICE:  ALTER TABLE / ADD EXCLUDE will create implicit
index "enforce_spatially_unique_rast" for table "t1"
psql:t1.sql:4: NOTICE:  Unable to add constraint: enforce_spatially_unique_rast
psql:t1.sql:4: NOTICE:  SQL used for failed constraint: ALTER TABLE
public.t1 ADD CONSTRAINT enforce_spatially_unique_rast EXCLUDE
((rast::geometry) WITH =)
psql:t1.sql:4: NOTICE:  Returned error message: relation
Shall I open a ticket?
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
