[postgis-devel] C-Library function returning PostGIS point crashing backend
David Fuhry
dfuhry at gmail.com
Thu Jan 10 07:57:08 PST 2013
I'm trying to write a C-Library function to return a PostGIS point. It's
crashing the backend when called:
=> select test2();
The connection to the server was lost. Attempting reset: Failed.
Minimal Makefile, .c, and .sql files are attached. Any suggestions on
what I might be doing wrong? I tried to mimic existing functions found in
PostGIS, examples at
http://trac.osgeo.org/postgis/wiki/DevWikiPostGISCoding, and
other code I found like the KM_ToLLA function at
https://github.com/kmatzen/PG_LLA_ECEF/blob/master/pg_lla_ecef.c.
=> select version();
PostgreSQL 9.2.1 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
4.4.5-8) 4.4.5, 64-bit
=> select postgis_full_version();
POSTGIS="2.0.1SVN r9750" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.7.8" LIBJSON="UNKNOWN"
(PostGIS raster and topology are not installed.)
Thanks,
Dave
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130110/3fac6660/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130110/3fac6660/attachment.obj>
Type: text/x-csrc
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130110/3fac6660/attachment.c>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130110/3fac6660/attachment-0001.obj>
