[postgis-devel] Rant on SRID -1 vs 0
maplabs at light42.com maplabs at light42.com
Mon Jul 15 14:23:43 PDT 2013
I was around during this discussion..
(most respect to SWoodbridge and some empathy for the frustration.. but..)
2.0 was clearly a major change, with the binary format of geometry
first and foremost..
If there was any time to make a somewhat  arbitrary change like the
"unassigned" value,
2.0 was arguably the best time to do it..
Personally, the zero value makes more sense to me, and I think I said
so at that time also
$0.02
Brian M Hamlin
OSGeo California Chapter
On Mon, 15 Jul 2013 17:10:51 -0400, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
I need to vent some frustration with the the change from srid=-1 to
> srid=0 for the undefined projection because this totally breaks
> scripts and makes it very hard to test things like pgrouting that
> need to work on both 1.5, 2.0 and 2.1.
> For example:
> select addgeometrycolumn('unnoded', 'the_geom', 0, 'LINESTRING', 2);
> does not work on  POSTGIS="1.5.3" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel.
> 4.8.0, 6 March 2012" LIBXML="2.7.8" USE_STATS
> And this is just the first of the problems I'm trying to track down.
> The second is the change in behavior of st_startpoint() with multi
> geometries and the change of st_geometryn() with simple geometry.
> This forces every function that uses these to check the postgis
> version conditionally implement access.
> Grummble, gummble, gummble, off to find some kind of solution(s).
> -Steve
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
