[postgis-devel] Ack! postgis.control is not getting install!
Daniel Kastl
daniel at georepublic.de
Sat Jun 8 07:15:54 PDT 2013
On Sat, Jun 8, 2013 at 11:03 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Dev,
> The current postgis-2.1.0beta3dev.tar.gz and svn are not installing the
> postgis.control file. The other two control files are there.
> Poor Daniel has been setting a travis instance for pgrouting and puzzling
> over this issue because we require pulling 2.1 and doing a local build and
> install from that for pgrouting. So I guess we running a postgis build-bot
> also :)
Well, Steve told me that the postgis-2.1.0beta3dev.tar.gz is changing every
night, which explains that it worked still 4 days ago. I thought it would
be a "stable" beta.
As a Travis newbie I thought I messed up something with the install script
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130608/47d4624f/attachment.html>
