[postgis-devel] Ack! postgis.control is not getting install!
Stephen Mather
mather.stephen at gmail.com
Sat Jun 8 07:52:39 PDT 2013
Ah, only for the dev version. Sorry, should read better... .
On Sat, Jun 8, 2013 at 10:50 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Guys,
> Sorry about this I'll check on this issue why no control file. No
> postgis-2.1.0beta3dev is not stable. That is why I put a dev at the end of
> it.
> The one you want to use for stability has no dev --- postgis-2.1.0beta2
> http://www.postgis.net/2013/05/11/postgis-2-1-0beta2
> Sorry for the confusion. I changed from our standard development
> extension (SVN to dev) in case one day we won't be using SVN.
> As a general rule, we always put our tagged builds on our osgeo download
> site.
> Thanks,
> Regina
> *From:* postgis-devel-bounces at lists.osgeo.org [mailto:
> postgis-devel-bounces at lists.osgeo.org] *On Behalf Of *Daniel Kastl
> *Sent:* Saturday, June 08, 2013 10:16 AM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] Ack! postgis.control is not getting
> install!
> On Sat, Jun 8, 2013 at 11:03 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> Hi Dev,
>> The current postgis-2.1.0beta3dev.tar.gz and svn are not installing the
>> postgis.control file. The other two control files are there.
>> Poor Daniel has been setting a travis instance for pgrouting and puzzling
>> over this issue because we require pulling 2.1 and doing a local build and
>> install from that for pgrouting. So I guess we running a postgis build-bot
>> also :)
> Well, Steve told me that the postgis-2.1.0beta3dev.tar.gz is changing
> every night, which explains that it worked still 4 days ago. I thought it
> would be a "stable" beta.
> As a Travis newbie I thought I messed up something with the install script
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130608/b08ed6e1/attachment.html>
