[postgis-devel] Is postgis 1.5.4 supported on pg 9.2?
Daniel Kastl
daniel at georepublic.de
Mon Jun 10 07:15:32 PDT 2013
On Mon, Jun 10, 2013 at 11:05 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Hi all,
> Is PostGIS 1.5.4 supported on pg 9.2? I need to do some pgrouting testing
> for some 1.5 issues but I only have pg 9.2 installed locally.
Hi Steve,
According to this matrix it's not supported:
http://trac.osgeo.org/postgis/wiki/UsersWikiPostgreSQLPostGIS
Daniel
> Is there a patch for this or do I need to find another system with pg 9.1
> or something else?
> Thanks,
> -Steve
> When I try to build I get the following error:
> gcc -fPIC -pie -I/usr/include/mit-krb5 -DLINUX_OOM_ADJ=0 -Wall
> -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement
> -Wendif-labels -Wmissing-format-attribute -Wformat-security
> -fno-strict-aliasing -fwrapv -g -fpic -I/usr/local/include
> -I/usr/include/libxml2 -I../liblwgeom -I. -I. -I/usr/include/postgresql/9.2/
> **server -I/usr/include/postgresql/**internal -D_GNU_SOURCE
> -I/usr/include/libxml2 -I/usr/include/tcl8.5 -c -o lwgeom_estimate.o
> lwgeom_estimate.c
> lwgeom_estimate.c: In function âLWGEOM_gist_joinselâ:
> lwgeom_estimate.c:318: error: âForm_pg_classâ undeclared (first use in
> this function)
> lwgeom_estimate.c:318: error: (Each undeclared identifier is reported only
> once
> lwgeom_estimate.c:318: error: for each function it appears in.)
> lwgeom_estimate.c:318: error: expected â;â before âreltupâ
> lwgeom_estimate.c:319: error: âreltupâ undeclared (first use in this
> function)
> lwgeom_estimate.c:330: error: expected â;â before âreltupâ
> make[1]: *** [lwgeom_estimate.o] Error 1
> make[1]: Leaving directory `/u/software/postgis-1.5.4/**postgis'
> make: *** [postgis] Error 2
> ______________________________**_________________
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-**bin/mailman/listinfo/postgis-**devel<http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130610/e1af5de5/attachment.html>
