[postgis-devel] [pgrouting] need help with std::bad_alloc issue
Stephen Woodbridge woodbri at swoodbridge.com
Tue Jun 11 08:32:47 PDT 2013
On 6/11/2013 10:58 AM, Bborie Park wrote:
> Steve,
> On what platform? Windows? Linux?
Linux, pg 9.2.4
> By the looks of it (I'm not very good at C++), std::bad_alloc comes
> from a failed new allocation. Run gdb or valgrind yet?
Yes, gdb is not vary useful because the postgresql is compiled with -PIE
and gdb does not support that well. valgrind is my friend I have run it
before but it does not report anything useful in this case.
I'm not great with C++ either, but I'm stuck on that fact that this
seems like C++ does not know how much memory is available so it fails
but after connecting to the database it seems to have a better idea.
We use a lot of std::vector structures, these are arrays that get
dynamically extended and as a result have a lot of realloc equovalents
on them the causes memory fragmentation, can where possible I have
changed the code to reserve a minimum size which has helped a lot, but
this kind of issue is consistently reproduced regardless of reconnecting.
I'll take another run at it with valgrind, but I'm pretty sure this will
not show anything new.
Thanks,
   -Steve
> -bborie
> On Tue, Jun 11, 2013 at 7:33 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>> Hi devs,
>> I have run into a strange problem with some pgrouting functions that you
>> guys might have already seen in postgis.
>> We have stored procedures that are C and C++ and in general they work fine,
>> but if I create a database, connect to it, create extensions and run some
>> commands I get std::bad_alloc error. If I simply reconnect to the database,
>> the same command does not generate an error, and, in fact, if I reconnect
>> after installing the extension, I never get this error.
>> I have traced this down to the particular statement that is throwing the
>> error, but there is nothing unique or particular about it. And we have seen
>> this behavior in multiple commands.
>> So I have to conclude that:
>> 1. we use the same pattern for most of our commands so that might be flawed
>> in some basic way regarding memory
>> 2. that there  is something strange about create extension in that the
>> libraries are not getting initialized correctly (or completely?) until a
>> connection is made. We are trying to verify this is or is not unique to pg
>> 9.2.
>> 3. pgrouting installs multiple shared libraries in our extension and maybe
>> postgresql assumes there is only going to be one shared library
>> 4. or something else totally different that we are missing
>> So has anyone seen anything like this with postgis code?
>> Any thoughts on what this might be? or how to run it down?
>> I did post post a inquiry to the postgresql list and Tom responded with not
>> enough information and to compile the server with --enable-cassert which I
>> did (assuming my Debian recompile worked correctly), but since this is a C++
>> error and not a postgresql palloc issue we have not seen and cassert errors.
>> Thoughts?
>> -Steve
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
