[postgis-devel] loadling gml data in to post gis with different geometry types
dustymugs
dustymugs at gmail.com
Thu Jun 20 09:56:45 PDT 2013
Dave,
PostGIS doesn't require you to predefine the type for a geometry field.
I'm betting that ogr2ogr is doing that.
By the looks of ogr2ogr's docs, you should be able to use the "-nlt"
flag... ogr2ogr -nlt GEOMETRY
-bborie
On 06/20/2013 04:59 AM, Dave Potts wrote:
> Hi,
> I am trying to load some gml data into a post gis database, the problem
> being that the gml data has linesstrings and points defined in it.
> The problem being that postgis requires you to predefine the type of a
> geomtry field
> What I would like to be able to do get a data table which has a shared
> geomtry column, failing that. I like to have a data table with two
> geomtry columns in it
> I have tried things like
> ogr2ogr -append -where "OGR_GEOMETRY='Point'" -f PostgreSQL "PG:
> dbname='${DB_NAME}'" -lco GEOMETRY_NAME=point_geom ${GML_FILE}
> ogr2ogr -append -where "OGR_GEOMETRY='LineString'" -f PostgreSQL "PG:
> dbname='${DB_NAME}'" -lco GEOMETRY_NAME=line_geom ${GML_FILE}
> But I get a volley of errors from ogr2ogr
> Layer creation options ignored since an existing layer is being
> appended to.
> Any suggestions ?
> Dave.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
