[postgis-devel] 2.0.4 ?
Sandro Santilli
strk at keybit.net
Wed Jun 26 09:35:56 PDT 2013
I got the testcase, but I shall notice that PostGIS build scripts
are currently using a single digit for each version component of GEOS,
so releasing 3.3.9 will force us to change that as soon as we need
to support 3.3.10 :)
Add to it that there are currently 13 open tickets with milestone
GEOS 3.3.9:
http://trac.osgeo.org/geos/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&milestone=3.3.9
I think it takes more time before getting it out of the door.
--strk;
On Wed, Jun 26, 2013 at 02:14:20PM +0200, Sandro Santilli wrote:
> On Wed, Jun 26, 2013 at 03:39:12AM -0400, Paragon Corporation wrote:
> > Strk it would be nice if you released GEOS 3.3.9 first don't you think :)
> For packagers ? Possibly.
> I was +1 on PostGIS 2.0.4 because it wasn't ME having to do it :)
> A GEOS-3.3.9 could be done, but I'm waiting for a testcase about
> HotPixel code first.
> --strk;
> > -----Original Message-----
> > From: postgis-devel-bounces at lists.osgeo.org
> > [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
> > Sent: Wednesday, June 26, 2013 3:26 AM
> > To: PostGIS Development Discussion
> > Subject: Re: [postgis-devel] 2.0.4 ?
> > On Tue, Jun 25, 2013 at 03:35:25PM -0700, Paul Ramsey wrote:
> > > It's been 3 months since the last 2.0 point release and a moderate number
> > of fixes have built up, anyone object to a 2.0 patch release?
> > Changes, for the record:
> > PostGIS 2.0.4
> > 2013/MM/DD
> > * Bug Fixes *
> > - #2110, Equality operator between EMPTY and point on origin
> > - Allow adding points at precision distance with TopoGeo_addPoint
> > - #1968, Fix missing edge from toTopoGeom return
> > - #2201, ST_GeoHash wrong on boundaries
> > - #2257, GBOX variables not initialized when testing with empty geometries
> > - #2271, Prevent parallel make of raster
> > - #2267, Server crash from analyze table
> > - #2277, potential segfault removed
> > - Fix build with systemwide liblwgeom installed
> > * Enhancements *
> > - #2269, Avoid uselessly detoasting full geometries on ANALYZE
> > +1 for me to release 2.0.4
> > --strk;
