[postgis-devel] Export from schema with pgsql2shp broken forWindows 64?
Paragon Corporation
lr at pcorp.us
Wed Mar 13 03:24:37 PDT 2013
Jeff,
Must have been because it was my birthday I missed that one. :)
I've ticketed the issue and confirmed it is an issue still in 2.0.3
http://trac.osgeo.org/postgis/ticket/2230
We had a similar issue with shp2pgsql (which affected 32-bit as well), and I
suspect the fix might be the similar.
It's really the schema parsing that is screwed up not what specific schema.
So if you have a schema in your search path and don't specify the schema in
output it seems to work fine.
Thanks,
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Jeff Lounsbury
Sent: Tuesday, March 12, 2013 6:40 PM
To: postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] Export from schema with pgsql2shp broken
forWindows 64?
In reference to:
http://postgis.17.n6.nabble.com/Export-from-schema-with-pgsql2shp-broken-for
-Windows-64-td4999002.html
Did anyone ever follow up on this, I don't see any open bugs for it and I am
getting the same behavior in my 64-bit Windows install now.
Pgsql2shp.exe (release 2.0.1 (r9979)) says the table doesn't exist but if I
run "\d <schema>.<Tablename>" it lists in a psql window just fine.
Exporting a table in the public schema works just fine.
Cheers,
-Jeff
postgis-devel mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
