[postgis-devel] --with-cgal
Paul Ramsey
pramsey at cleverelephant.ca
Mon Mar 25 12:05:05 PDT 2013
That is to say, PostGIS will need --with-sfcgal
P
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On Monday, March 25, 2013 at 3:04 PM, Sandro Santilli wrote:
> On Mon, Mar 25, 2013 at 02:57:48PM -0400, Olivier Courtin wrote:
> > On Mar 25, 2013, at 2:48 PM, Paul Ramsey wrote:
> > > Discussed at the sprint: beginning to bring CGAL into the fold. First step would be adding CGAL to the build, optionally, with --with-cgal. Initial uses could be voronoi diagram generation, and of course enhanced 3D algorithm support.
> > As we just said here:
> > Right now CGAL is a need to 3D algorithm support, but we also need
> > SF-CGAL in the middle to be able to interact between PostGIS Simple
> > Feature model and CGAL model.
> > SF-CGAL is implemented in C++, and should remain as a separate library.
> > cf: https://github.com/Oslandia/SFCGAL
> Is that to say PostGIS does NOT need --with-cgal ?
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
