[postgis-devel] force_sfs
Oliver Courtin olivier.courtin at oslandia.com
Thu May 9 12:51:15 PDT 2013
Hi all,
Related to SFCGAL implementation (#2254)
i had to add an extra PostGIS function,
to allow using only geometry types that GEOS is able to handle.
So something like a curve_to_line with in more, theses conversions:
 - TIN -> MULTIPOLYGON
 - TRIANGLE -> POLYGON
 - POLYHEDRALSURFACE -> MULTIPOLYGON
Dimensions are kept unchanged
Right now i've called it ST_force_sfs
Do you have an opinion on such a thing
(about naming or prototype or behavior ?)
Behaviour:
liblwgeom/cunit/cu_force_sfs,c
Prototype:
CREATE OR REPLACE FUNCTION ST_force_sfs(geometry) RETURNS geometry
O.
