[postgis-devel] Building the extension on Solaris/amd64
Martin Spott Martin.Spott at mgras.net
Wed May 15 14:09:41 PDT 2013
Mark Cave-Ayland wrote:
> On 15/05/13 14:28, Martin Spott wrote:
>> Since release preparations for 2.1.0 had been announced, I tried SVN
>> trunk on Solaris10.  See #2331
> I think this is a liblwgeom dependency problem rather than a
> Solaris-specific problem. I've seen this recently when switching from
> building 2.0 branch to 2.1 branch and it's because the build is picking
> up liblwgeom from a PostGIS 2.0 installation already on the same machine.
Sure, I knew this could happen - and in order to ensure I'm not mixing
different header versions, I stopped everything and removed the entire
2.0 install beforehand.
I'll re-check again, thanks for responding,
	Martin.
 Unix _IS_ user friendly - it's just selective about who its friends are !
