[postgis-devel] Building the extension on Solaris/amd64
Paul Ramsey
pramsey at cleverelephant.ca
Wed May 15 15:22:02 PDT 2013
What an unpredictable development...
http://lists.osgeo.org/pipermail/postgis-devel/2011-September/014926.html
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On Wednesday, May 15, 2013 at 1:24 PM, Mark Cave-Ayland wrote:
> On 15/05/13 14:28, Martin Spott wrote:
> > Martin Spott wrote:
> > > Sure, the extension/grep works properly now. Anyhow there are different
> > > build issues on Solaris with SVN trunk (2.0.2 works fine) which I'll
> > > try to outline as soon as time permits [...]
> > Since release preparations for 2.1.0 had been announced, I tried SVN
> > trunk on Solaris10. See #2331
> > Cheers,
> > Martin.
> I think this is a liblwgeom dependency problem rather than a
> Solaris-specific problem. I've seen this recently when switching from
> building 2.0 branch to 2.1 branch and it's because the build is picking
> up liblwgeom from a PostGIS 2.0 installation already on the same machine.
> The quick solution is to cd into liblwgeom and do a "make install" there
> first, then go back to the main Makefile and you should find that the
> build will complete successfully.
> Strk - can you take a look at this with a matter of urgency? I managed
> to recreate it by simply doing a complete build of PostGIS 2.0 followed
> by PostGIS 2.1 on the same box from my git clone. Otherwise it's going
> to trip up an awful lot of people trying to upgrade...
> ATB,
> Mark.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
