[postgis-devel] Building the extension on Solaris/amd64
Sandro Santilli strk at keybit.net
Thu May 16 01:47:55 PDT 2013
On Wed, May 15, 2013 at 11:32:31PM +0100, Mark Cave-Ayland wrote:
> So the actual bug is that the build system is choosing the
> pre-installed system header rather than the locally-generated header
> at compile time - perhaps the Makefile is missing a dependency
> somewhere?
I can build & install postgis-2.0 and then build & make check a
postgis-2.1 without problems on my system (ubuntu linux).
Can I have access to the Solaris box ? I suspect it's a difference
in how the linker resolves library names...
--strk;
