[postgis-devel] Building the extension on Solaris/amd64
Paragon Corporation
lr at pcorp.us
Sat May 18 10:34:27 PDT 2013
While we are at it any chance we can have it stop installing in system
folders if its not asked for. I don't know how it happens but liblwgeom.a
and friends always happen to sneak into
My msys\local\lib during make install and I suspect this is causing
problems during my regress testing of shp2pgsql-gui on 32-bit
As noted here: http://trac.osgeo.org/postgis/ticket/2158
I have my postgis regress tmp_dir and install folders set .
I personally preferred the static build as it was much less prone to error
and would be really happy if we got back to that state of affairs.
BTW: The buildbot scripts for winnie are here:
http://trac.osgeo.org/postgis/browser/buildbots/windows/mingw64/scripts
Primary ones are regress_postgis.sh and build_postgis.sh
She checks to see if they are changed on each build run of postgis and pulls
the latest.
If you can see anything I am doing wrong here I'm all ears or if you want to
change them even better.
Thanks,
Regina
http://www.postgis.us
http://postgis.net
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Mark Cave-Ayland
Sent: Saturday, May 18, 2013 8:12 AM
To: Martin Spott; postgis-devel at lists.osgeo.org
Subject: Re: [postgis-devel] Building the extension on Solaris/amd64
On 17/05/13 23:54, Sandro Santilli wrote:
> Could you guys try with r11470 please ?
Yes, that works for me - thanks a lot! I do have one further question - is
it sensible to make the same change to 2.0 branch too? Otherwise I can see
that the problem still exists in reverse, i.e. doing a git checkout on 2.1
then switching to 2.0 will cause a similar error since the liblwgeom
APIs/headers don't match.
(I appreciate that a downgrade in this way isn't a problem for most people
in the same way that the original bug report was, however for developers
with an up-to-date copy of the repository it completely eliminates any
potential problems caused by switching between versions).
ATB,
Mark.
postgis-devel mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
