[postgis-devel] Building the extension on Solaris/amd64
Martin Spott
Martin.Spott at mgras.net
Sat May 25 10:17:12 PDT 2013
Sandro Santilli wrote:
> Note that in the scenario above the next iteration finds
> the dumpfile name NOT starting with a dash, which is enough
> to stop. But if your filename really starts with a dash you're
> indeed doomed.
Actually it wasn't enough to stop and my dumpfile name didn't start
with a dash.
In Perl "while", in order to exit a loop, it's _not_ sufficient not to
have a "true" condition, instead you really need an explicit "false".
Cheers,
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
