[postgis-devel] SNapPointToLine : GEOS : where is the code for st_intersects between line and point?
Rémi Cura
remi.cura at gmail.com
Wed Nov 6 02:15:12 PST 2013
Hey Nicklas,
thanks for your answer.
I'm simply trying to solve a problem in current ST_Intersects behavior
regarding a point and a line. IN most of the case, a point on a line(to
double limit precision) is not on the line for st_intersects !
it works as intended in very very few cases (ie, all the points that
intersects a line is a very sparse set and is not a line at all !).
Here is a simple illustration : http://hpics.li/c3485b5 represents a line
with max zoom : it is all the point that follow the line equation and are
rounded to the(16 or 17 digits)
http://hpics.li/f30aeb7 now the big points represents the point that are on
the line for ST_Intersect, in a favorable case (bad case could mean no
points at all).
This is without speaking of custom precision model, ie working with the
postgis 'infinite' precision (double precision, 15 to 17 digits)
I tried several workaround (like several random walk along the line to find
a point that st_intersects like,
and also reverse engineer to find which points are seen on the line by
st_intersects (related to prime factorization of slope it appears) ).
The issue is there is a flaw in ST_Intersects and in bad cases there is no
workaround.
Could you elaborate about 'native' functions please?
Cheers,
Rémi-C
2013/11/6 Nicklas Avén <nicklas.aven at jordogskog.no>
> I think postgis has native functions for st_intersects when at least one
> of the geometries is a point. And there is two paths in the code. One that
> prepares the "not point" geometry if it is to be used multiple times and
> one that doesn't.
> I do not get the idea do far. Is it a tolerance you are implementing?
> Best regards
> Nicklad
> Skickat från min Samsung Mobil
> -------- Originalmeddelande --------
> Från: Rémi Cura <remi.cura at gmail.com>
> Datum: 06-11-2013 8:59 (GMT+01:00)
> Till: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Rubrik: [postgis-devel] SNapPointToLine : GEOS : where is the code for
> Hey,
> I've been working on a ST_SnapPointToLine for the past week,
> by reverse engineering when points are considered to be on line by
> st_intersect.
> The (classic) problem is purely a numerical issue, and I suspect a problem
> in design of st_intersects.
> So far my solution doesn't work for all line, can someone please point me
> in the right direction in GEOS so I can see if something can be improved
> regarding precision.
> I know where the API is, but I'm looking for the exact part that decide if
> a point and a line intersects.
> Cheers,
> Rémi-C
> postgis-devel mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131106/6c23cd62/attachment.html>
