[postgis-devel] SNapPointToLine : GEOS : where is the code for st_intersects between line and point?
Rémi Cura
remi.cura at gmail.com
Wed Nov 6 04:41:21 PST 2013
Hey Sandro =) ,
thanks for the answer and the suggestion ( switching to geos-devel)
*(Hey geos list, please see the message history in reverse order)*
I'm not looking for infinite precision, just *coherent* double precision.
Using double precision to represent a line/point gives you a representation
like pixels in images, where size of pixel in x is min precision in (that
is a round to 15 to17 digits) (same in y). This is not an issue (for me).
This issue is not about geometry being approximated (rounded), but about
st_intersects miss-computing with this rounded geom.
Currently st_intersects computing for a point and a line is false, more
exactly the computing seems to be more precise than the geometry, thus
giving false answer.
I'm not sure about this, and i don't know either what kind of change could
solve this problem.
Maybe the computing of "robust determinant" needs to be relaxed a bit to
output 0 in close cases.
I can give you example of points being exactly on the double precision grid
(ie 17 digits in each coordinate), exactly on the theoretical line (up to
10^-30), and yet rejected by st_intersects.
Cheers,
Rémi-C
2013/11/6 Sandro Santilli <strk at keybit.net>
> On Wed, Nov 06, 2013 at 11:15:12AM +0100, Rémi Cura wrote:
> > This is without speaking of custom precision model, ie working with the
> > postgis 'infinite' precision (double precision, 15 to 17 digits)
> Double precision is not 'infinite'.
> Maybe CGAL would give you a closer approximation, but GEOS doesn't support
> the CGAL-like arbitrary precision.
> You might want to subscribe to geos-devel and start a thread there if
> you intend to work on that side of the architecture.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
Hey Nicklas,
thanks for your answer.
I'm simply trying to solve a problem in current ST_Intersects behavior
regarding a point and a line. IN most of the case, a point on a line(to
double limit precision) is not on the line for st_intersects !
it works as intended in very very few cases (ie, all the points that
intersects a line is a very sparse set and is not a line at all !).
Here is a simple illustration : http://hpics.li/c3485b5 represents a line
with max zoom : it is all the point that follow the line equation and are
rounded to the(16 or 17 digits)
http://hpics.li/f30aeb7 now the big points represents the point that are on
the line for ST_Intersect, in a favorable case (bad case could mean no
points at all).
I tried several workaround (like several random walk along the line to find
a point that st_intersects like,
and also reverse engineer to find which points are seen on the line by
st_intersects (related to prime factorization of slope it appears) ).
The issue is there is a flaw in ST_Intersects and in bad cases there is no
workaround.
Could you elaborate about 'native' functions please?
Cheers,
Rémi-C
2013/11/6 Nicklas Avén <nicklas.aven at jordogskog.no>
> I think postgis has native functions for st_intersects when at least one
> of the geometries is a point. And there is two paths in the code. One that
> prepares the "not point" geometry if it is to be used multiple times and
> one that doesn't.
> I do not get the idea do far. Is it a tolerance you are implementing?
> Best regards
> Nicklad
> Skickat från min Samsung Mobil
> -------- Originalmeddelande --------
> Från: Rémi Cura <remi.cura at gmail.com>
> Datum: 06-11-2013 8:59 (GMT+01:00)
> Till: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
> Rubrik: [postgis-devel] SNapPointToLine : GEOS : where is the code for
> Hey,
> I've been working on a ST_SnapPointToLine for the past week,
> by reverse engineering when points are considered to be on line by
> st_intersect.
> The (classic) problem is purely a numerical issue, and I suspect a problem
> in design of st_intersects.
> So far my solution doesn't work for all line, can someone please point me
> in the right direction in GEOS so I can see if something can be improved
> regarding precision.
> I know where the API is, but I'm looking for the exact part that decide if
> a point and a line intersects.
> Cheers,
> Rémi-C
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131106/49ab664f/attachment.html>
