[postgis-devel] PostGIS 2.1.1 Released
Paragon Corporation lr at pcorp.us
Fri Nov 8 13:27:08 PST 2013
 I've generated the docs so doc links now working.
-----Original Message-----
Sent: Friday, November 08, 2013 3:49 PM
To: 'PostGIS Development Discussion'
Subject: RE: [postgis-devel] PostGIS 2.1.1 Released
Paul,
Link to Docs on news release is broken.
http://postgis.net/2013/11/08/postgis-2.1.1
And  also missing in News reel
#2511, Support for materialized views and foreign tables in geometry_columns
Though I guess that one was missed since it was also pushed into 2.0.5 so we
might be missing some others.
It just occurred to me, I'm not sure we ever fixed for geography_columns and
I assume it has the same issue.
Hope that helps,
Regina
http://www.postgis.us
http://postgis.net
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
Sent: Friday, November 08, 2013 3:12 PM
To: postgis-users at lists.osgeo.org; postgis-devel at lists.osgeo.org
Subject: [postgis-devel] PostGIS 2.1.1 Released
Get it while it's hot!
http://download.osgeo.org/postgis/source/postgis-2.1.1.tar.gz
 * Important Changes *
- #2514, Change raster license from GPL v3+ to v2+, allowing distribution of
PostGIS Extension as GPLv2.
* Bug Fixes *
- #2396, Make regression tests more endian-agnostic
- #2434, Fix ST_Intersection(geog,geog) regression in rare cases
- #2454, Fix behavior of ST_PixelAsXXX functions regarding
exclude_nodata_value parameter
- #2449, Fix potential infinite loop in index building
- #2489, Fix upgrades from 2.0 leaving stale function signatures
- #2493, Fix behavior of ST_DumpValues when passed an empty raster
- #2502, Fix postgis_topology_scripts_installed() install schema
- #2504, Fix segfault on bogus pgsql2shp call
- #2512, Support for foreign tables and materialized views in raster_columns
and raster_overviews
- #2525, Fix handling of SRID in nested collections
- #2528, Fix memory leak in ST_Split / lwline_split_by_line
- #2532, Add missing raster/geometry commutator operators
- #2533, Remove duplicated signatures
* Enhancements *
- #2463, support for exact length calculations on arc geometries
- #2478, support for tiger 2013
- #2527, Added -k flag to raster2pgsql to skip checking that band is NODATA
Paul Ramsey | Boundless
http://boundlessgeo.com/support/postgis
2508850632 | @pwramsey
postgis-devel mailing list
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
