[postgis-devel] SFCGAL : trouble installing
Rémi Cura
remi.cura at gmail.com
Mon Oct 14 06:17:05 PDT 2013
Hey Olivier ,
thanks for the answer !
great news for 2.2, I hope I'll be able to try sfcgal before that :-)
Still not working, what am I doing wrong?
su postgres
cd /usr/share/postgresql/9.3/contrib/postgis-2.1/
psql -d test_sfcgal -p 5433 < postgis.sql
test_sfcgal being a data base created for the test.
the postgis.sql breaks at the 2nd statement with the classical :
ERROR: could not load library "/usr/lib/postgresql/9.3/lib/postgis-2.1.so":
libSFCGAL.so: cannot open shared object file: No such file or directory
État SQL :58P01
what now?
It seems like postgis has no link to libsfcgal.so.
Can I manually set it?
make check in postgis goves the same error old error.
Cheers,
Rémi-C
2013/10/14 Olivier Courtin <olivier.courtin at oslandia.com>
> On Oct 14, 2013, at 12:30 PM, Rémi Cura wrote:
> Hi Rémi,
> I would like to use SFCGAL but can't make it work.
> And try to add postgis
> - CREATE EXTENSION postgis VERSION '2.1.0';
> Here is the issue.
> Right now (and until 2.2.0) sfcgal don't use EXTENSION
> so need to create the spatial database with the old school method:
> psql database < postgis.sql
> psql database < spatial_ref_sys.sql
> psql database < sfcgal.sql
> Should be enough to make it works.
> I also will look why you did'nt get the 1.0.2 right version number.
> O.
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131014/c64dd318/attachment.html>
