[postgis-devel] constructor for CIRCULARLINE(pt1,pt2,pt3)
Rémi Cura remi.cura at gmail.com
Wed Oct 16 05:35:59 PDT 2013
Hey,
I'm working with curves,
and I can't find a constructor except passing by WKT then GeomFromText.
I did a simple plpgsql function to try to reduce the hassle, but it is a
binary hack : changing the binary value indicating linestring to binary
value indicating circularline, according to WKB definition. It still makes
many casts.
*This is very dirty*, does anybody have better suggestion?
Rémi-C
The function and test code :
DROP FUNCTION IF EXISTS public.rc_MakeArc(p1 geometry, p2 geometry, p3
geometry);
CREATE FUNCTION public.rc_MakeArc(p1 geometry, p2 geometry, p3 geometry)
RETURNS geometry AS
$BODY$
--this function create a curve geometry based on input 3 points. Points are
supposed to be in the natural order along the curve
DECLARE
result geometry := NULL;
t text;
query text;
BEGIN
--the trick is  to create first a linestring, then to change the WKB
reprensentation, going from 2 to 8 to change from line string to
circularstring
RETURN geometry(
set_byte(
ST_AsBinary(
ST_MakeLine(ARRAY[p1,p2,p3])
)::bytea
,1,8)
END ;
$BODY$
LANGUAGE plpgsql IMMUTABLE;
SELECT ST_AsText(public.rc_MakeArc(
'point(1 1)'::geometry,--p1 geometry
'point(0 0)'::geometry,-- p2 geometry
'point(1 -1)'::geometry -- p3 geometry
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131016/3a207508/attachment.html>
