[postgis-devel] New function ST_DumpSegments?? (was : utility function : linestring -> setof segment)
Rémi Cura remi.cura at gmail.com
Thu Oct 31 01:21:51 PDT 2013
Thanks for your suggestions it is very kind.
Sadly it can't work .
I thought about something else,
 I'll simply go the git way from another connection, without firewall.
Cheers,
Rémi-C
2013/10/30 Sandro Santilli <strk at keybit.net>
> On Wed, Oct 30, 2013 at 05:40:28PM +0100, Rémi Cura wrote:
> > I can't use neither svn nor github easily due to very strict firewall.
> You can clone the git repo over HTTP:
> git clone http://github.com/postgis/postgis.git
> > I was thinking about sending only modified files.
> You can still send diff if you backup the original files
> before modifying them. Or the whole tree.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20131031/07a79996/attachment.html>
