[postgis-devel] PostGIS-2.0.4 ?
Paul Ramsey pramsey at cleverelephant.ca
Wed Sep 4 13:38:31 PDT 2013
It lives! Sounds good to me, there was some GEOS-based objection last time. Regina?
P.
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On Wednesday, September 4, 2013 at 1:36 PM, Sandro Santilli wrote:
> What about cutting a 2.0.4 release ?
> 2.0.3 was released on March 1st, 2013
> Changes since then:
> * Bug Fixes *
> - #2110, Equality operator between EMPTY and point on origin
> - Allow adding points at precision distance with TopoGeo_addPoint
> - #1968, Fix missing edge from toTopoGeom return
> - #2165, ST_NumPoints regression failure with CircularString
> - #2168, ST_Distance is not always commutative
> - #2186, gui progress bar updates too frequent
> - #2201, ST_GeoHash wrong on boundaries
> - #2257, GBOX variables not initialized when testing with empty geometries
> - #2271, Prevent parallel make of raster
> - #2267, Server crash from analyze table
> - #2277, potential segfault removed
> - #2307, ST_MakeValid outputs invalid geometries
> - #2351, st_distance between geographies wrong
> - #2359, Incorrect handling of schema for overview constraints
> - #2371, Support GEOS versions with more than 1 digit in micro
> - #2372, Cannot parse space-padded KML coordinates
> - Fix build with systemwide liblwgeom installed
> - #2383, Fix unsafe use of \' in warning message
> - #2410, Fix segmentize of collinear curve
> - #2415, ST_Multi support for COMPOUNDCURVE and CURVEPOLYGON
> - #2412, ST_LineToCurve support for lines with less than 4 vertices
> - #2420, ST_LineToCurve: require at least 8 edges to define a full circle
> - #2423, ST_LineToCurve: require all arc edges to form the same angle
> - #2424, ST_CurveToLine: add support for COMPOUNDCURVE in MULTICURVE
> - #2427, Make sure to retain first point of curves on ST_CurveToLine
> * Enhancements *
> - #2269, Avoid uselessly detoasting full geometries on ANALYZE
> * Known Issues *
> - #2111, Raster bands can only reference the first 256 bands of out-db rasters
> There are 14 tickets targetted at 2.0.4, which make the most annoying part of
> cutting the relase (they should be moved upward, maybe to 2.1.1 directly...).
> http://trac.osgeo.org/postgis/query?status=assigned&status=new&status=reopened&order=priority&col=id&col=summary&col=status&col=type&col=priority&col=milestone&col=component&milestone=PostGIS+2.0.4
> What do you think ?
> --strk;
> http://www.cartodb.com - Map, analyze and build applications with your data
> ~~ http://strk.keybit.net
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
