[postgis-devel] GEOS-3.3.9 released
Sandro Santilli
strk at keybit.net
Wed Sep 4 14:37:28 PDT 2013
After 6 months of bugfixes, the 3.3.9 release of GEOS is available.
Download: http://download.osgeo.org/geos/geos-3.3.9.tar.bz2
Bug fixes / improvements since 3.3.8:
- Fix OffsetCurve op in presence of duplicated vertices (#602)
- Fix LineSegmentVisitor copy ctor (#636)
- Fix area boundary return from GEOSPointOnSurface (#623)
- Speedup GEOSWKBReader_read (#621)
- Fix RobustLineIntersector handling of invalid intersection points (#622)
- Reduce likelyhood of invalid output from snap operation (#629, #501)
- Reduce memory fragmentation of prepared Polygon/Point intersection op
- Fix mingw64 compile (#630)
- Fix bug in HotPixel constructor (#635)
- Fix install location of linearref headers (#624)
- Fix multi-geometry constructor to drop SRID from components (#583)
--strk;
