[postgis-devel] [OT] postgresql raise notice is giving me a major headache
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 6 06:07:01 PDT 2013
One error appears to be a new TSP error that has suddenly popped up
since we have not made any changes there for months. I'll look at this
over the weekend.
I just checked in a change to fix a problem with the notice checking
which will hopefully clear 3 of the issues on 9.2.
-Steve
On 9/6/2013 2:54 AM, Paragon Corporation wrote:
> Steve,
> I presume the differences in errors I'm seeing on winnie are because of the
> notice issue.
> pg 9.3 'z_crash' => 0,
> 'z_fail' => 1,
> 'z_pass' => 64
> pg 9.2
> 'z_crash' => 0,
> 'z_fail' => 4,
> 'z_pass' => 61
> pg 9.1
> 'z_crash' => 0,
> 'z_fail' => 1,
> 'z_pass' => 64
> I haven't looked closely at them to see. I thought I had notice checking
> disabled though so perhaps something different since I do recall
> Before they were all passing.
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org
> [mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
> Sent: Thursday, September 05, 2013 6:58 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] [OT] postgresql raise notice is giving me a
> major headache
> Not really, you can see that we had to write our own regression harness
> (run_test) as soon as we supported multiple versions of PgSQL.
> P
> Paul Ramsey
> http://cleverelephant.ca
> http://postgis.net
> On Thursday, September 5, 2013 at 3:51 PM, Stephen Woodbridge wrote:
>> Hi all,
>> We have a bunch of functions in pgrouting that output a lot of
>> informational NOTICE messages to the user.
>> In our automated tests, we collect the command output and compare it to
>> a reference file. The headache is the no two versions of postgresql
>> output the same format for these messages. So a lot of our test fail
>> with false positive errors. We are testing on pg versions 9.0, 9.1 and
>> 9.2 and I guess we should be adding 9.3 soon also.
>> I guess the obvious answer is to not compare the notice messages. But I
>> don't like that answer.
>> Any better thoughts on this?
>> -Steve
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org (mailto:postgis-devel at lists.osgeo.org)
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
