[postgis-devel] typmod parser at sql level ?
Sandro Santilli
strk at keybit.net
Thu Sep 26 09:31:14 PDT 2013
On Thu, Sep 26, 2013 at 09:21:44AM -0700, Paul Ramsey wrote:
> Can't recall offhand, will have to Use the Source, Luke.
The Source will be with me, always:
uninstall_postgis.sql:DROP FUNCTION IF EXISTS postgis_typmod_dims (integer);
uninstall_postgis.sql:DROP FUNCTION IF EXISTS postgis_typmod_srid (integer);
uninstall_postgis.sql:DROP FUNCTION IF EXISTS postgis_typmod_type (integer);
uninstall_postgis.sql:DROP FUNCTION IF EXISTS geometry_typmod_in (cstring[]);
uninstall_postgis.sql:DROP FUNCTION IF EXISTS geometry_typmod_out (integer);
uninstall_postgis.sql:DROP FUNCTION IF EXISTS geography_typmod_in (cstring[]);
uninstall_postgis.sql:DROP FUNCTION IF EXISTS geography_typmod_out (integer);
Thanks for the wisdom.
--strk;
