[postgis-devel] a slight error in postgis TopologySummary
    Rémi Cura
    remi.cura at gmail.com
    Thu Sep 26 09:31:36 PDT 2013
Yes,
 you are right of course,
and I turn to postgis topo after having considered cgal.
And I'm very gratefull not to have to recode all the topology extension !
I'm not expecting perfection, but I'm testing on very small subset and very
simple geometries ,
and yet it breaks after processing 3 polygons ...
I'm not sure it is a precision problem but I'll definitively look into that
with new version.
If the bug is also in new version I'll do a snippet and a ticket.
Cheers,
Rémi-C
2013/9/26 Sandro Santilli <strk at keybit.net>
> On Thu, Sep 26, 2013 at 05:32:30PM +0200, Rémi Cura wrote:
> > OK,
> > thanks !
> > Now I understand.
> > I'm placing all my hope in this 2.1 version, as I can't work with the
> > current version.
> Let me know.
> Note that there's no way you can get code with no possibility of hitting
> robustness issues. It's just not available with finite precision.
> Not implemented in CGAL, not implemented in boost::geometry.
> It currently doesn't exist, so don't look for it.
> Instead, organize your workflow to expect exception and react to them.
> The good thing about persistent topology is that you could
> loose nothing and work on the specific problematic geometries.
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20130926/5dd2a2f7/attachment.html>
