[postgis-devel] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
    Paul Ramsey
    pramsey at cleverelephant.ca
    Tue Apr 22 12:38:48 PDT 2014
make it so +1
On Sat, Apr 19, 2014 at 5:52 PM, Bborie Park <dustymugs at gmail.com> wrote:
> +1 for release of 2.1.3 jar.
> On Sat, Apr 19, 2014 at 5:47 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Baris,
>> Regarding this:
>> > Here is my proposal: I can take care of the last  targeted 2.1 release
>> > which is 2.1.3 and change pom.xmls as I did in the trunk and apply shanes
>> > patches and after the release of 2.1.3 I can manually sign the jars and
>> > submit them to OSSRH. And keep discussing the separation of
>> > repositories on trunk.
>> +1 for that.  Others in PSC and development please vote on this as well so
>> we can start moving on this.
>> I think we'll be releasing a 2.1.3 fairly soon.  2.2.0 we are looking at
>> at least another 4 months and that's being hopeful :)
>> Thanks,
>> Regina
>> http://www.postgis.us
>> http://postgis.net
>> ________________________________
>> From: postgis-users-bounces at lists.osgeo.org
>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Baris Ergun
>> Sent: Saturday, April 19, 2014 4:50 AM
>> To: PostGIS Users Discussion
>> Cc: PostGIS Development Discussion
>> Subject: Re: [postgis-users] [postgis-devel] looking for a public well
>> known maven repository for postgis-jdbc 2.1 and later on versions
>> Hi Shane;
>> People are busy with other stuff so until we decide to separate the
>> repositories for postgis java projects I have applied ur patches to both
>> jdbc and jdbc_jtsparser projects. So what this means is "when we release
>> 2.2.0 postgis I would be ready to submit these two jars manually to OSSRH".
>> Baris
>> On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
>>> Hi Baris,
>>> Oops, I didn't see that you were already chasing this down. Your approach
>>> sounds great, thanks for taking the lead on this! In the past there have
>>> been issues with other projects having non-resolvable dependencies on
>>> versions of postgis-jdbc (Hibernate Spatial), so it will be great to have
>>> these artifacts in the central repo.
>>> Best,
>>> Shane
>>> On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com>
>>> wrote:
>>>> Hi Shane;
>>>> Thanks for ur patch and consideration. I think we are on the same path
>>>> if u check the issue #2626. I have applied the OSSRH and got the credentials
>>>> for being able to upload postgis jdbc jars to central maven rep. For that
>>>> case I have separated the jdbc and jdbc-jtsparser jars on the trunk and
>>>> updated the pom.xml's according to Central maven repository requirements..
>>>> On the trunk actually I was waiting to agree  with all the developers to
>>>> separate the postgis jdbc jars  repository and continue with 1st suggested
>>>> approach.  If we do that way we wouldnt need to make the explicit plugin
>>>> declarations as you patched in 2702.
>>>> submit them to OSSRH. And keep discussing the separation of repositories on
>>>> trunk.
>>>> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
>>>>> I don't have any objections.  +1 for that.
>>>>> Thanks,
>>>>> Regina
>>>>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shane StClair
>>>>> Sent: Saturday, April 05, 2014 5:24 PM
>>>>> Subject: Re: [postgis-users] looking for a public well known maven
>>>>> Sounds good. Any objection to the community manually uploading pre-2.2
>>>>> versions to Maven Central?
>>>>> Thanks,
>>>>> Shane
>>>>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us>
>>>>> wrote:
>>>>>> Shane,
>>>>>> I think we can change our build bot to upload to maven as part of the
>>>>>> official release job when we build tagged docs etc.  Have to talk over with
>>>>>> rest of PostGIS psc and dev folks on that.
>>>>>> I guess before that we'll need to completely cleanup the issues with
>>>>>> our current jdbc which sounds like we are close.  Thanks for the patch BTW.
>>>>>> Thanks,
>>>>>> Regina Obe
>>>>>> PostGIS PSC member
>>>>>> http://postgis.net
>>>>>> Sent: Saturday, April 05, 2014 3:29 PM
>>>>>> To: postgis-users at lists.osgeo.org
>>>>>> Subject: [postgis-users] looking for a public well known maven
>>>>>> I just submitted a patch [1] to generate javadoc and source jars as
>>>>>> part of the postgis-jdbc build. Otherwise, the existing pom meets the Maven
>>>>>> Central sync requirements [2].
>>>>>> There are two options for getting up to date postgis-jdbc releases
>>>>>> into Maven Central. The first would be for Maven Central deployment to
>>>>>> become part of the postgis release process. After the initial setup the
>>>>>> Maven Central publishing process isn't terribly painful, but it would
>>>>>> require a postgis developer to assume responsibility for the Maven Central
>>>>>> submission and for postgis-jdbc to get special consideration during releases
>>>>>> [3] [4].
>>>>>> The other option would be to have the community manually upload to
>>>>>> Maven Central [5]. This is definitely not the ideal situation, but if Maven
>>>>>> Central uploads are out of scope for the postgis devs right now it would
>>>>>> allow us to get updated versions into the central repo. A blessing from the
>>>>>> postgis devs would help in this second case.
>>>>>> Thanks,
>>>>>> Shane
>>>>>> [1] http://trac.osgeo.org/postgis/ticket/2702
>>>>>> [2]
>>>>>> https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
>>>>>> [3]
>>>>>> https://maven.apache.org/guides/mini/guide-central-repository-upload.html
>>>>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
>>>>>> [5]
>>>>>> https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+to+The+Central+Repository
>>>>>> Shane StClair
>>>>>> Software Engineer
>>>>>> Axiom Consulting & Design
>>>>>> http://www.axiomalaska.com
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>> Shane StClair
>>>>> Software Engineer
>>>>> postgis-devel mailing list
>>>>> postgis-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>>>> Barış
>>> Shane StClair
>>> Software Engineer
>> Barış
