[postgis-devel] PSC/Development Vote -- Baris to release upcoming 2.1.3 jars and manually sign
Paragon Corporation lr at pcorp.us
Mon Apr 28 11:55:38 PDT 2014
Baris,
Possibly stupid questions
1) What is the jdbc_jtsparser for vs. the current jdbc
2) Can we have parent pom at root of Java that runs the child poms
right now in Jenkins I have two separate jobs going -- 1 to build the jdbc
and one to build the jdbc_jtsparser. Both get dumped here:
http://postgis.net/stuff/
 For some reason (possibly ineptness on my part), I can't get this into one
maven job.
It's my understanding that if we have a parent pom (possibly in java
folder), I can just call that to build both.
http://stackoverflow.com/questions/13988469/maven-multi-module-pom-and-jenki
ns-jobs
Is that possible or am I totally misunderstanding this.
Thanks,
Regina
  _____
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Baris Ergun
Sent: Saturday, April 26, 2014 2:08 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] PSC/Development Vote -- Baris to release
Hi;
Only that jdbc_jtsparser project can also be added to Jenkins projects for
both branches/2.1 and trunk. No other specific script necessary.
(java/jdbc_jtsparser) running  'mvn clean install' on code changes would be
enough.
Thanks.
Baris.
On 26 April 2014 07:06, Paragon Corporation <lr at pcorp.us> wrote:
Baris,
Yes we do have  a continuous integration bot. Do you have a script I can
schedule her to run or is what is running so far okay.
Currently have this job which runs for jdbc.
http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_2.1_JDBC/
 As far as I can tell last run was successful
http://debbie.postgis.net:8080/view/PostGIS/job/PostGIS_2.1_JDBC/558/console
If you do have a script, just commit it to this folder:
http://trac.osgeo.org/postgis/browser/buildbots/debian/scripts
(I don't have all her scripts in subversion yet but is on my todo)
Thanks,
Regina
  _____
Sent: Friday, April 25, 2014 4:53 PM
Completed the task and tested the building of artifacts on branches/2.1
basically now we have separate jdbc and jdbc_jtsparser projects (which must
be built consecutively). Do we have an continuous integration server where I
can integrate? Otherwise I will have to ask for your help on verification.
On 24 April 2014 13:41, Baris Ergun <barisergun75 at gmail.com> wrote:
Okey than will start soon.
On 22 April 2014 22:38, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
make it so +1
On Sat, Apr 19, 2014 at 5:52 PM, Bborie Park <dustymugs at gmail.com> wrote:
> +1 for release of 2.1.3 jar.
> On Sat, Apr 19, 2014 at 5:47 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Baris,
>> Regarding this:
>> > Here is my proposal: I can take care of the last  targeted 2.1 release
>> > which is 2.1.3 and change pom.xmls as I did in the trunk and apply
shanes
>> > patches and after the release of 2.1.3 I can manually sign the jars and
>> > submit them to OSSRH. And keep discussing the separation of
>> > repositories on trunk.
>> +1 for that.  Others in PSC and development please vote on this as well
so
>> we can start moving on this.
>> I think we'll be releasing a 2.1.3 fairly soon.  2.2.0 we are looking at
>> at least another 4 months and that's being hopeful :)
>> Thanks,
>> Regina
>> http://www.postgis.us
>> http://postgis.net
>> ________________________________
>> From: postgis-users-bounces at lists.osgeo.org
>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Baris Ergun
>> Sent: Saturday, April 19, 2014 4:50 AM
>> To: PostGIS Users Discussion
>> Cc: PostGIS Development Discussion
>> Subject: Re: [postgis-users] [postgis-devel] looking for a public well
>> known maven repository for postgis-jdbc 2.1 and later on versions
>> Hi Shane;
>> People are busy with other stuff so until we decide to separate the
>> repositories for postgis java projects I have applied ur patches to both
>> jdbc and jdbc_jtsparser projects. So what this means is "when we release
>> 2.2.0 postgis I would be ready to submit these two jars manually to
OSSRH".
>> Baris
>> On 7 April 2014 21:26, Shane StClair <shane at axiomalaska.com> wrote:
>>> Hi Baris,
>>> Oops, I didn't see that you were already chasing this down. Your
approach
>>> sounds great, thanks for taking the lead on this! In the past there have
>>> been issues with other projects having non-resolvable dependencies on
>>> versions of postgis-jdbc (Hibernate Spatial), so it will be great to
have
>>> these artifacts in the central repo.
>>> Best,
>>> Shane
>>> On Sun, Apr 6, 2014 at 2:29 AM, Baris Ergun <barisergun75 at gmail.com>
>>> wrote:
>>>> Hi Shane;
>>>> Thanks for ur patch and consideration. I think we are on the same path
>>>> if u check the issue #2626. I have applied the OSSRH and got the
credentials
>>>> for being able to upload postgis jdbc jars to central maven rep. For
that
>>>> case I have separated the jdbc and jdbc-jtsparser jars on the trunk and
>>>> updated the pom.xml's according to Central maven repository
requirements..
>>>> On the trunk actually I was waiting to agree  with all the developers
to
>>>> separate the postgis jdbc jars  repository and continue with 1st
suggested
>>>> approach.  If we do that way we wouldnt need to make the explicit
plugin
>>>> declarations as you patched in 2702.
shanes
repositories on
>>>> trunk.
>>>> On 6 April 2014 05:32, Paragon Corporation <lr at pcorp.us> wrote:
>>>>> I don't have any objections.  +1 for that.
>>>>> Thanks,
>>>>> Regina
>>>>> [mailto:postgis-users-bounces at lists.osgeo.org] On Behalf Of Shane
StClair
>>>>> Sent: Saturday, April 05, 2014 5:24 PM
>>>>> Subject: Re: [postgis-users] looking for a public well known maven
>>>>> Sounds good. Any objection to the community manually uploading pre-2.2
>>>>> versions to Maven Central?
>>>>> Thanks,
>>>>> Shane
>>>>> On Sat, Apr 5, 2014 at 1:38 PM, Paragon Corporation <lr at pcorp.us>
>>>>> wrote:
>>>>>> Shane,
>>>>>> I think we can change our build bot to upload to maven as part of the
>>>>>> official release job when we build tagged docs etc.  Have to talk
over with
>>>>>> rest of PostGIS psc and dev folks on that.
>>>>>> I guess before that we'll need to completely cleanup the issues with
>>>>>> our current jdbc which sounds like we are close.  Thanks for the
patch BTW.
>>>>>> Thanks,
>>>>>> Regina Obe
>>>>>> PostGIS PSC member
>>>>>> http://postgis.net
StClair
>>>>>> Sent: Saturday, April 05, 2014 3:29 PM
>>>>>> To: postgis-users at lists.osgeo.org
>>>>>> Subject: [postgis-users] looking for a public well known maven
>>>>>> I just submitted a patch [1] to generate javadoc and source jars as
>>>>>> part of the postgis-jdbc build. Otherwise, the existing pom meets the
Maven
>>>>>> Central sync requirements [2].
>>>>>> There are two options for getting up to date postgis-jdbc releases
>>>>>> into Maven Central. The first would be for Maven Central deployment
to
>>>>>> become part of the postgis release process. After the initial setup
the
>>>>>> Maven Central publishing process isn't terribly painful, but it would
>>>>>> require a postgis developer to assume responsibility for the Maven
Central
>>>>>> submission and for postgis-jdbc to get special consideration during
releases
>>>>>> [3] [4].
>>>>>> The other option would be to have the community manually upload to
>>>>>> Maven Central [5]. This is definitely not the ideal situation, but if
Maven
>>>>>> Central uploads are out of scope for the postgis devs right now it
would
>>>>>> allow us to get updated versions into the central repo. A blessing
from the
>>>>>> postgis devs would help in this second case.
>>>>>> Thanks,
>>>>>> Shane
>>>>>> [1] http://trac.osgeo.org/postgis/ticket/2702
>>>>>> [2]
https://docs.sonatype.org/display/Repository/Central+Sync+Requirements
>>>>>> [3]
https://maven.apache.org/guides/mini/guide-central-repository-upload.html
>>>>>> [4] http://central.sonatype.org/pages/ossrh-guide.html
>>>>>> [5]
https://docs.sonatype.org/display/Repository/Uploading+3rd-party+Artifacts+t
o+The+Central+Repository
>>>>>> Shane StClair
>>>>>> Software Engineer
>>>>>> Axiom Consulting & Design
>>>>>> http://www.axiomalaska.com
>>>>>> _______________________________________________
>>>>>> postgis-users mailing list
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
>>>>> Shane StClair
>>>>> Software Engineer
>>>>> postgis-devel mailing list
>>>>> postgis-devel at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
>>>> Barış
>>> Shane StClair
>>> Software Engineer
>> Barış
Barış
Barış
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140428/77d75bd6/attachment.html>
