[postgis-devel] TWKB_agg broken ?
Sandro Santilli
strk at keybit.net
Wed Aug 6 09:40:15 PDT 2014
Nicklas, I was looking at ST_AsTWKB_agg but I think it's broken.
Why would otherwise the output of ST_AsTWKB_agg be smaller than
the output of ST_AsTWKB ?
See below:
strk=# select sum(octet_length(o)) from ( select ST_AsTWKB(g,0) o from
( select the_geom g from lots_of_points limit 10000 ) b ) f;
sum
60000
(1 row)
Time: 15.936 ms
strk=# select sum(octet_length(o)) from ( select ST_AsTWKB_agg(g,0) o from
sum
20006
(1 row)
Time: 13.248 ms
--strk;
() ASCII ribbon campaign -- Keep it simple !
/\ http://strk.keybit.net/rants/ascii_mails.txt
