[postgis-devel] TWKB_agg broken ?
Nicklas Avén
nicklas.aven at jordogskog.no
Thu Aug 7 01:44:40 PDT 2014
2014-08-07 Sandro Santilli wrote:
On Wed, Aug 06, 2014 at 07:04:34PM +0200, Nicklas Avén wrote:
>> On on., 2014-08-06 at 18:40 +0200, Sandro Santilli wrote:
>> > Nicklas, I was looking at ST_AsTWKB_agg but I think it's broken.
>> > Why would otherwise the output of ST_AsTWKB_agg be smaller than
>> > the output of ST_AsTWKB ?
>> It is possible because the aggregate version uses delta values between
>> the points which often gives smaller values to store.
>Is there no separator between records in the output of the aggregator ?
>How's it different from collecting the geometries and passing the
>collection to ST_AsTWKB ?
The differnce is that by using ST_AsTWKBagg you won't loose the individual id:s.
If you use ST_Collect it will just be a collection.
/Nicklas
>--strk;
> () ASCII ribbon campaign -- Keep it simple !
> /\ http://strk.keybit.net/rants/ascii_mails.txt
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140807/a0eb3e6a/attachment.html>
