[postgis-devel] Geography getting bounding box cache for points if cast directly to geography but not if cast from bytea to geography
Paragon Corporation lr at pcorp.us
Fri Aug 15 22:33:28 PDT 2014
I'm not sure this is a bug or not, but the inconsistency is beginning to bug
me.
This I observed when testing
http://trac.osgeo.org/postgis/ticket/2870
For linestrings this yields same
select ST_Summary('LINESTRING(151.215289 -33.856885, 151
-33)'::geometry::geography) ;
select ST_Summary('LINESTRING(151.215289 -33.856885, 151 -33)'::geography) ;
LineString[BGS] with 2 points
For points
SELECT  ST_Summary('POINT(151.215289 -33.85688)'::geometry::geography) ;
Gives Point[BGS]
But casting staight to geography or from bytea gives:
select  ST_Summary('POINT(151.215289 -33.85688)'::geography) ;
select  ST_Summary('POINT(151.215289 -33.85688)'::bytea:geography) ; --
(note if you don't see GS for this one then you aren't running the latest
#2870 update)
Point[GS]
Why on earth should this make a difference and what bounding box are we
getting back?
Thanks,
Regina
