[postgis-devel] address standardizer extension
Paragon Corporation lr at pcorp.us
Wed Aug 27 03:17:34 PDT 2014
It doesn't?  It automatallically gets built as far as make ? I thought it
did as part of make install as well.  Have to double check my scripts (I may
just read from the extensions folder instead of postgres folder so could be
mistaken on the make install part)
-----Original Message-----
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Sandro Santilli
Sent: Wednesday, August 27, 2014 6:12 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] address standardizer extension
On Wed, Aug 27, 2014 at 05:41:27AM -0400, Paragon Corporation wrote:
> I haven't incorporated changes into configure.ac yet.  Just the logic
> to generate the make files.  My plan is to build it as part of the
> make install script if all the prequisites are present.
Ok. Please build it as part of "make" though, and only install it as part of
"make install" :)
The extensions/Makefile.in file should be changed to optionally add
address_standardizer to SUBDIRS.
Btw, looking at it, postgis_tiger_geocoder is also missing.
Should it have the same threatment ?
--strk;
> From: postgis-devel-bounces at lists.osgeo.org
> Santilli
> Sent: Wednesday, August 27, 2014 5:18 AM
> To: postgis-devel at lists.osgeo.org
> Subject: [postgis-devel] address standardizer extension
> Is it normal for the address standardizer extension to not be built
> automatically on "make" ? I ask because it is found under the
> extension/ dir. If it's not to be integrated it should reside in the
> extra/ dir instead.
> --strk;
>  ()  ASCII ribbon campaign  --  Keep it simple !
>  /\  http://strk.keybit.net/rants/ascii_mails.txt
> postgis-devel mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
