[postgis-devel] Postgis Raster JPEG 2000 (openjpeg)
Nathaniel Clay
clay.nathaniel at gmail.com
Mon Feb 17 18:32:06 PST 2014
Hi all,
This is just some food for thought and discussion. I've take a cursory look
at JPEG 2000 openjpeg. I think it may hold promise for a possible future
format or co-format for Postgis Raster in database storage.
- Supports both Loss less and Lossful Compression approaching the
performance of ERDAS ( uncompressed Gtif 200M, openjpeg JP2 25M Lossfull
and 80M Lossless, ERDAS JP2 15M)
- I don't have a ERADAS encoder license, but this image was of the
same original
- Openjpeg lossfull compression in my opinion visually identical to
the original with default settings
- Supports N band imagery
- Multi-Resolution Packing
- eg more than one raster resolution with in the "code stream"
- can be ordered by user specification, default smallest to largest
- This would allow us to get rid of the overview tables or make them
views.
http://ericportis.com/posts/2014/resolution-progressive-jpeg2000-performance/
- Extensible header
- SRID, IPX,IPY, etc
- Area of interest specification
- Allows you to specify a region with in the same raster to have a
higher bitrate, etc
- Error Detection and Correction
- Openjpeg project seems to be alive last commit was a few days a go.
- BSD License
Possible Concerns identified so far:
- Writes require a recode of the entire tile, however the tile size is
user specifiable
- takes a long time to encode image, ~10 sec on my system with the test
image ( 3067x3777 8bit 4bands)
- I dont have anything to compare it to, so I dont know if this is a
good or bad
- I havent tested on small image size and other possible scenarios.
- Memory Usage seemed high during decode and encode, ~2G, I believe
this is due to the decoder and encoder preallocate memory for all of the
"Pyramids" and bands at once. (but have not investigated thoroughly) (
Image Res 3067x 3777 8bit 4 bands)
- Its included decoder application has weird issues with tif, other
formats are fine. ( Dont think it has anything to do with the openjpeg lib)
- May be indective of other problems
If I were to start on this project it would be some time in the future and
I would most likely require help and lots of input, but I thought I it
would be a good idea to bring, it up as a discussion point.
Any thoughts,
Nathaniel Hunter Clay
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140217/f41fd849/attachment.html>
