[postgis-devel] Java Maintenance
Nicklas Avén nicklas.aven at jordogskog.no
Tue Feb 25 14:05:00 PST 2014
This sounds great to me.
I don't know enough about Java but do we have any thoughts about that the code shall work with the open Java alternatives?
In many Linux distributions Oracle Java is a pain to keep updated with manual updating. Especially since they release a new security release about once a week.
/Nicklas
Skickat från min Samsung Mobil
-------- Originalmeddelande --------
Från: Paul Ramsey <pramsey at cleverelephant.ca>
Datum: 25-02-2014  21:25  (GMT+01:00)
Till: PostGIS Development Discussion <postgis-devel at lists.osgeo.org>
Kopia: Baris Ergun <barisergun75 at gmail.com>
Rubrik: [postgis-devel] Java Maintenance
Hi Devs,
We have the potential for active maintenance of the Java chunk of the distribution, and I would like to give Baris Ergun commit privs to the java sub-tree. He’s already provided a couple of patches that look fine, and most importantly is thinking about the implications of his changes in the large before applying.
Please give me a vote on that (the alternative is continuing Java branch bitrot)
P
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On February 25, 2014 at 10:51:52 AM, Baris Ergun (barisergun75 at gmail.com) wrote:
Hi Paul;
Did u have a chance to check the issue
Thanks.
On 20 February 2014 22:15, Baris Ergun <barisergun75 at gmail.com> wrote:
I have updated the issue with Alternative approaches. Your version number concern still floating. According to preferred approach we can continue to discuss.
On 16 February 2014 02:42, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
Please see my ticket comment. I’m worried about having a version number flapping along in there.
P.
Paul Ramsey
http://postgis.net
On February 15, 2014 at 10:57:18 AM, Baris Ergun (barisergun75 at gmail.com) wrote:
Hi Paul;
I have generated a git patch for the git mirror of svn-trunk. It basically removes unnnecessary lines in pom.xml and prepared against sonatype guide. If you can review and apply this patch and the next coming related patches quickly It would help my communication with Sonatype guys. Basically the mvn clean install still works for everyone checking out the codes. The changes will be affecting only publishing to Central rep so I hope it wont break anyones build etc.. And also publishing to Central rep is not active at the moment so it wont break anything on that path since it is already broken.
I have already opened a Sonatype Jira ticket for publishing of postgis-jdbc jars to Sonatype Central repository.
Thanks.
Barış
www.linkedin.com/in/barisergun
Barış
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140225/07f3e5b8/attachment.html>
