[postgis-devel] Java Maintenance
Paragon Corporation lr at pcorp.us
Tue Feb 25 19:00:44 PST 2014
+1 from me too.
  _____
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Bborie Park
Sent: Tuesday, February 25, 2014 3:26 PM
To: PostGIS Development Discussion
Cc: Baris Ergun
Subject: Re: [postgis-devel] Java Maintenance
+1. Bit-rot bad...
-bborie
On Tue, Feb 25, 2014 at 12:25 PM, Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
Hi Devs,
We have the potential for active maintenance of the Java chunk of the
distribution, and I would like to give Baris Ergun commit privs to the java
sub-tree. He's already provided a couple of patches that look fine, and most
importantly is thinking about the implications of his changes in the large
before applying.
Please give me a vote on that (the alternative is continuing Java branch
bitrot)
P
Paul Ramsey
http://cleverelephant.ca
http://postgis.net
On February 25, 2014 at 10:51:52 AM, Baris Ergun (barisergun75 at gmail.com)
wrote:
Hi Paul;
Did u have a chance to check the issue
Thanks.
On 20 February 2014 22:15, Baris Ergun <barisergun75 at gmail.com> wrote:
I have updated the issue with Alternative approaches. Your version number
concern still floating. According to preferred approach we can continue to
discuss.
On 16 February 2014 02:42, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
Please see my ticket comment. I'm worried about having a version number
flapping along in there.
P.
Paul Ramsey
http://postgis.net
On February 15, 2014 at 10:57:18 AM, Baris Ergun (barisergun75 at gmail.com)
wrote:
Hi Paul;
I have generated a git patch for the git mirror of svn-trunk. It basically
removes unnnecessary lines in pom.xml and prepared against sonatype guide.
If you can review and apply this patch and the next coming related patches
quickly It would help my communication with Sonatype guys. Basically the mvn
clean install still works for everyone checking out the codes. The changes
will be affecting only publishing to Central rep so I hope it wont break
anyones build etc.. And also publishing to Central rep is not active at the
moment so it wont break anything on that path since it is already broken.
I have already opened a Sonatype Jira ticket for publishing of postgis-jdbc
jars to Sonatype Central repository.
Thanks.
Barış
www.linkedin.com/in/barisergun
Barış
postgis-devel mailing list
postgis-devel at lists.osgeo.org
http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140225/dab4a0a6/attachment.html>
