[postgis-devel] Travis Failing with Weird Error on My MapAlgebraMask Pull Request
Paragon Corporation
lr at pcorp.us
Fri Jan 3 10:26:34 PST 2014
For reference I have this ticketed so when resolved please close out ticket.
http://trac.osgeo.org/postgis/ticket/2594
It's a little bizzarre that its only travis failing -- winnie and debbie
seem fine. The same issue on 2.1.2 tests though and I didn't think your
commit was in 2.1.2. saw thought it was something else.
Thanks,
Regina
_____
[mailto:postgis-devel-bounces at lists.osgeo.org] On Behalf Of Nathaniel Hunter
Clay
Sent: Friday, January 03, 2014 1:19 PM
To: postgis-devel at lists.osgeo.org
Subject: [postgis-devel] Travis Failing with Weird Error on My
Hi everyone,
Travis is failing on my pull request, however I am able to get a clean build
on 9.3 and 9.1, make test that runs both the SQL and cunit test with out a
problem. However Travis is failing with the following error:
$ cat /tmp/pgis_reg/*
createlang: language "plpgsql" is already installed in database
"postgis_reg"
SET
BEGIN
DO
CREATE FUNCTION
psql:/home/travis/build/postgis/postgis/regress/00-regress-install/share/con
trib/postgis/postgis.sql:86: ERROR: could not load library
"/home/travis/build/postgis/postgis/regress/00-regress-install/lib/postgis-2
.2.so":
/home/travis/build/postgis/postgis/regress/00-regress-install/lib/postgis-2.
2.so: undefined symbol: palloc0
I am stuck, any help would be appreciated.
Many Thanks,
Nathaniel Hunter Clay
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140103/c0e9e4a6/attachment.html>
