[postgis-devel] Travis Failing with Weird Error on My MapAlgebra Mask Pull Request
Bborie Park
dustymugs at gmail.com
Fri Jan 3 10:39:23 PST 2014
Usually, the windows build bot (winnie) is the complainer. At least from my
experience, isolated linux box failures occur from config issues.
-bborie
On Fri, Jan 3, 2014 at 10:35 AM, Nathaniel Hunter Clay <
clay.nathaniel at gmail.com> wrote:
> Thank you Dustymugs
> On 1/3/2014 1:27 PM, Bborie Park wrote:
> I'll test this tonight. I just haven't had much time lately.
> -bborie
> On Fri, Jan 3, 2014 at 10:18 AM, Nathaniel Hunter Clay <
>> Hi everyone,
>> Travis is failing on my pull request, however I am able to get a clean
>> build on 9.3 and 9.1, make test that runs both the SQL and cunit test with
>> out a problem. However Travis is failing with the following error:
>> $ cat /tmp/pgis_reg/*
>> createlang: language "plpgsql" is already installed in database
>> "postgis_reg"
>> SET
>> BEGIN
>> DO
>> CREATE FUNCTION
>> psql:/home/travis/build/postgis/postgis/regress/00-regress-install/share/contrib/postgis/postgis.sql:86:
>> ERROR: could not load library
>> "/home/travis/build/postgis/postgis/regress/00-regress-install/lib/
>> postgis-2.2.so":
>> postgis-2.2.so: undefined symbol: palloc0
>> I am stuck, any help would be appreciated.
>> Many Thanks,
>> postgis-devel mailing list
>> postgis-devel at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> postgis-devel mailing listpostgis-devel at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140103/660fc350/attachment.html>
