[postgis-devel] Postgis topology creation - O(n-squared)? - creates problems with large datasets.
Sandro Santilli strk at keybit.net
Mon Jan 20 05:05:37 PST 2014
On Mon, Jan 20, 2014 at 09:23:08AM +0000, Graeme B. Bell wrote:
> Good morning Sandro,
> > I've found the culprit!
> > It's a query in topology._ST_AddFaceSplit that fails to make use of the index
> > by checking for overlap between a literal and a function over the indexed
> > geometry, in this form:
> Fantastic work! Congratulations on finding it and fixing it. :-)
> This will help to enable us to try a small real-world project here.
Great! Looking forward for next advancement :)
> Incidentally - I made them with an open source package called 'rbuild' (confession: I'm the author). https://github.com/gbb/rbuild, if anyone is curious.
> I'll wrap up the rbuild topology script neatly and put it on github, and post to the list when it's ready.
> That way, people can generate topologies of any complexity they like, in any zone they like.
That'd be perfect for a performance test. It could be only enabled
when "rbuild" is found and feed a version-controlled configuration
to it!
> The asymptote on that curve is looking a lot more healthy :-)
You can see what I meant about "ST_CreateTopogeo" not being
optimized at all, it behaves the same as the incremental builder,
and often it even takes more time.
--strk;
 ()  ASCII ribbon campaign        - against html e-mail
 /\  http://www.asciiribbon.org   - against proprietary attachments
