[postgis-devel] Postgis topology creation - O(n-squared)? - creates problems with large datasets.
Sandro Santilli
strk at keybit.net
Tue Jan 21 04:00:50 PST 2014
On Tue, Jan 21, 2014 at 11:58:00AM +0100, Sandro Santilli wrote:
> On Tue, Jan 21, 2014 at 09:20:36AM +0000, Graeme B. Bell wrote:
> > - Profiling: currently, on large datasets, what 3-5 functions eat the most time in createTopo or the incremental approach, and why?
> ST_ModEdgeSplit is the most expensive function for the incremental approach.
> It performs checks that are not needed when called from the internal population
> function. An improvement would be splitting the function into an internal one
> and an external one, and calling the internal from internal code. This has been
> done successfully in other cases.
As for CreateTopoGeom (batch approach), here are the stats for adding the
first 10 polygons in the test dataset:
strk=# select * from pg_stat_user_functions order by total_time desc limit 10; funcid | schemaname | funcname | calls | total_time | self_time
54510 | topology | st_createtopogeo | 1 | 125.349 | 7.153
54503 | topology | st_addedgemodface | 10 | 93.129 | 40.687
62973 | topology | _st_addfacesplit | 20 | 48.949 | 32.145
54491 | topology | getringedges | 20 | 15.872 | 15.872
54508 | topology | st_addisonode | 10 | 13.167 | 12.953
54490 | topology | getnodebypoint | 20 | 6.564 | 5.568
52390 | public | st_unaryunion | 3 | 4.291 | 4.291
52429 | public | st_relate | 15 | 1.527 | 1.527
52436 | public | _st_intersects | 20 | 0.89 | 0.89
52331 | public | text | 200 | 0.785 | 0.785
Again API-level functions being called internally (ST_AddEdgeModFace,
ST_AddIsoNode).
--strk;
