[postgis-devel] Reg : Error while doing " create extension postgis; "
Manikanta Kondeti mani.iiit123 at gmail.com
Sat Jan 25 22:53:22 PST 2014
Hello sir ,
I'm using Ubuntu 12.04 . I remember that I had same problem  with QGIS last
time when I added this repositories. Tillmill is working in my lab system &
its not working in my system .  Anyway I will add this repositories  & do
my other work in lab . But just tell me if there is any alternative way
that I can work on both or should I update to Ubuntu 13.04 ? .
Thank you
Manikanta
Spatial Informatics
IIIT-H
On Sun, Jan 26, 2014 at 10:16 AM, Daniel Kastl <daniel at georepublic.de>wrote:
> Hi Manikanta,
> Which version of Ubuntu do you have troubles with?
> I remember that last year there was a change in the package naming of
> GDAL UbuntuGIS packages. So when I installed PostGIS 2.x it
> uninstalled QGIS. Still I have some troubles with Tilemill package for
> example, which requires the "original" package.
> For pgRouting though this should be resolved. CMake is only too old
> for Ubuntu 12.04, but there is a newer version in the pgRouting PPA.
> Daniel
> On Sun, Jan 26, 2014 at 5:53 AM, Manikanta Kondeti
> <mani.iiit123 at gmail.com> wrote:
> > Hello sir ,
> >       I heard that if add that repositories  cmake wont work & it will
> > remove all libraries linked with it . I have done a web application using
> > pgrouting in oct & nov , at that time I remember I had these libraries
> in my
> > system and it worked perfectly . In this month I was about to do my lab
> work
> > which needs cmake  , so I installed it again & it removed all the
> libararies
> > linked with pgrouting . I got this information from ubuntu people in
> IRC. Is
> > there any alternative way ,   Now what shall I do ??
> > Thank you ,
> > Manikanta
> > Spatial Informatics ,
> > IIIT-H
> > On Sat, Jan 25, 2014 at 7:52 PM, Stephen Woodbridge
> > <woodbri at swoodbridge.com> wrote:
> >> On 1/25/2014 5:46 AM, Manikanta Kondeti wrote:
> >>> Hello ,
> >>>       I am getting this error while installing a pgrouting algorithm
> >>> which is developed last year . I have also attached a screenshot of it
> >>> which shows the error .
> >>> Error :    could not load library
> >>> "/usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so
> >>> <http://rtpostgis-2.0.so>": /usr/local/lib/libgdal.so.1: version
> >>> `GDAL_1.8' not found (required by
> >>> /usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so <http://rtpostgis-2.0.so
> >> I would recommend adding adding the following ppa's
> >> http://ppa.launchpad.net/georepublic/pgrouting/ubuntu precise
> >> http://ppa.launchpad.net/ubuntugis/ppa/ubuntu precise
> >> http://apt.postgresql.org/pub/repos/apt/ precise-pgdg
> >> This should make the latest gis stack available on Ubuntu.
> >> -Steve W
> >> _______________________________________________
> >> postgis-devel mailing list
> >> postgis-devel at lists.osgeo.org
> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20140126/9b35a844/attachment.html>
